Help! Power Loss!!
Subscribe
May 18, 2004 | 01:58 PM
Just noticed yesterday that I have lost some power at upper RPM's. Runs smooth, no noise, oil pressure gauge same as always. It just doesn't "kick" when I put the pedal on the floor. Any thoughts?
Reply 0
May 18, 2004 | 02:12 PM
Fuel pressure. Fuel filter.
Reply 0
May 18, 2004 | 02:24 PM
Both replaced at 35,500 , 8/7/02. Current mileage 43,000. '91 944 S2 Cab.
Reply 0
May 18, 2004 | 02:27 PM
Has the cam timing shifted or not been timed properly? Needs two dial indicators on the #1 lobes to set it correctly.
Reply 0
May 18, 2004 | 02:30 PM
I am not mechanical enough to answer your question. Trying to get some ideas as ro what the trouble MIGHT be before I go to high-priced mechanic and get ripped!
Reply 0
May 18, 2004 | 02:43 PM
Another point: If the Hall sensor on the cam fails or any of the two knock sensors, the DME shifts the timing back over 4 degrees. This could be the loss of high end pep.
Reply 0
May 18, 2004 | 04:59 PM
Thanks SoCal !
Appreciate your thoughts.
Reply 0
May 20, 2004 | 06:36 PM
Bump...
Reply 0
Explore
May 20, 2004 | 06:46 PM
Any chance it could be your clutch? When mine was going, it slipped a little at high RPMs, not anything you could see on the Tach, but it definitely felt like a loss of power. When I pulled the old clutch it was down to the metal studs holding the friction material on.
Reply 0
May 20, 2004 | 06:56 PM
Quote:
Originally posted by Admin
Bump...
Admin??? what not John D.???
~Eyal
Reply 0
May 20, 2004 | 07:01 PM
knock sensors sound more appropriate causing that timing to retard.
Andy
Reply 0
May 20, 2004 | 07:08 PM
Hey don't call me that. I learned somethin new today!
Thanks!
Reply 0
May 20, 2004 | 07:21 PM
The clutch IS a possibility! Thanks!!
Reply 0
May 20, 2004 | 07:27 PM
What about vaccum?
Reply 0
May 20, 2004 | 07:51 PM
Could be a number of things - some mentioned above.
Easy and free: Check the plugs, wires, rotor, cap, coil to be in good "looking" order. Check the AFM trace and clean it (remove black cover from AFM, clean trace and wiper arm with eraser or Isopropyl Alcohol
Not cheap, but wise: If a tune-up is due, do it. Cap/rotor/plugs. I had a weak coil on my 86na that appears to have caused a flat spot in the 3500-4500 range - replaced with MSD6A (a little overkill). Run some fuel system cleaner through a full tank. Have the injectors cleaned and tested. There are some others but these are the most common and least costly.
If it's the clutch, it "should" change as you drive differently or on different grades - it's all related to force, not speed. The clutch on the 944 is hydraulically actuated - it's unlikely you'd only notice this on high revs.
Good Luck!
Reply 0
