Clutch Pedal - At the floor
The clutch pedal is compressed 2 inches from the floor. It now has 2-3 inches from engage to dis-engage. Is it hydrolic? If so, does it take brake fluid? I think it is leaking......
Hey Man
The first thing you check is if your brake reservoir is low, parked on a slope with low fluid can result in air getting into the clutch master supply line; not the best design for the reservoir.. It's either the master or slave cylinder. If you think you have leaks then maybe it's a hose to the slave. If your carpet padding is greasy behind the pedal, it's the master; if your slave is leaking into the clutch area (pull the rubber plug and feel for fluid) get it fixed immediately. If it's either the master or slave replace both. I just went through this awhile back. It's not that hard to replace both; 2 hours if your organized.
Good Luck
Good Luck
Failing slave cylinder.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Hey Man
I pulled the pedal up with my toe, seems to work fine now. Whats the story with that?
