Immediately upon startup, 88 944 na RPMs dip then level out at ~800
Old 05-16-2004 | 12:59 AM
Matt O.'s Avatar
Matt O.
Lifetime Member
Default Immediately upon startup, 88 944 na RPMs dip then level out at ~800
I think the 800 RPM is perfectly normal, however, when you start it up, the RPMs dip for a moment, then level off. Does anyone know the cause of this? And the remedy?
Thanks,
Matt
Old 05-16-2004 | 02:39 AM
Serge944's Avatar
Serge944
Our friend fr wilk knows about it more than I...
http://frwilk.com/early944/misc/shudder.htm
Old 05-16-2004 | 07:06 AM
Matt Sheppard's Avatar
Matt Sheppard
Could it be a faulty ISV valve?
Old 05-16-2004 | 10:56 PM
Matt O.'s Avatar
Matt O.
Lifetime Member
Serge, thanks for the link.
"Start the engine and turn the air bypass crew in to adjust the idle down. "
Any ideas where the air bypass crew [sic] is? I assume he meant "screw."
Thanks,
Matt
Old 05-16-2004 | 11:02 PM
Eyal 951's Avatar
Eyal 951
could also be TPS.
~Eyal
