Clicking under the passenger side of the dash
Hi,
Hope your driving season is getting going.
When starting my MY88 NA 5-speed there is a clicking under the passenger side of the dash for a minute or so and then stops. It sounds like a relay yet do not see any in the area.
I have had family members help to isolate this but no luck.
Not sure this matters--this vehicle has the alarm (does not appear related to that but not sure) and mobile phone wire running along the right-side of the rear seat and up the side panel behind the rear side glass and the hatch
Thanks in advance.
Thanks in advance.
I would suspect that it's the alarm. Probably cycling a relay for the horn. Check under the floor board of the passenger footwell. There is often a box next to the DME that contains the alarm. Just take the area apart and see if that is indeed what's clicking.
I believe its commonly caused by a shot/issue with the solenoid for the HVAC under the glove box area:
https://www.google.com/search?q=pors...hrome&ie=UTF-8
Solenoid for heating valve I believe (which you should be able to see somewhat from the passenger footwell looking up under the glove box area):
http://www.clarks-garage.com/shop-manual/hvac-01.htm
