Voltages and wiring for clock
I recently picked up a different clock along with a new genuine voltmeter for my 84 944, but I need some help referencing some wiring on a car that has a working clock. Specifically, I need to know if the clock always has power (which I'm 99% sure it does) and I also need to know what voltage is going to the clock (do I need a resistor or is it just battery voltage?).
I originally had ac in the car, but that has since been removed along with the climate control dial. I got a voltmeter to fill the hole in the center. What I would like to know for this is what ignition battery source is close to the gauge so that I can piggy back off of it
I did this to my car also. I remember using one of the AC plugs for the proper 12V source to the voltmeter. The only thing is it moves when the turn signal is on. Probably should have searched for a better source or ground, but at least it works fine.
