Bad ECU/DME?
I've been having a problem with my 944 where the car won't start or idle, the ECU/DME looks a little rough with corrosion and heat and I'm wondering what the signs of a bad DME is for the 944. What's the most normal thing to go wrong?
Heres the link to my long thread that shows what I've encountered on my 944 journey, it has some extra information about the car:
https://rennlist.com/forums/924-931-944-951-968-forum/1331459-944-hard-start-no-start.html
I sent some pictures of the ECU/DME to the previous owner of the car and he said the heat spots on the ECU/DME are new and he sent me pictures of when he had it apart and it looks much less crispy than the ECU/DME now. I'm going to source a new ECU/DME and will post on the thread if it's the issue.
also will the car start/run on starter fluid? if so check the wires to the injectors they fray n short out n since the car is batch fire if one shorts they all short
instead of sourcing a new old DME get a focus 9 tech F9T 944-SPEC DME (https://www.ftech9.com/new-products/944spec-dme)
Use this guide to further diagnose your Porsche:
https://cdn.shopify.com/s/files/1/25...w-up-Forms.pdf
Always good to check Clarks Garage - lots of good info there
http://www.clarks-garage.com/shop-manual/dme-05.htm
There is no easy way to test a DME other than swapping with a good known unit. Perhaps a member lives nearby with a similar year DME can help
This thread will not receive anymore updates from me, all issues have been solved and updates will be posted to the link below.
Link to origin story: https://rennlist.com/forums/924-931-...-no-start.html
