Can I reuse gaskets when installing test pipe?
The subject pretty much says it. When I install my new testpipe, can I reuse the existing gaskets at the flanges of the cat pipe I'll be replacing?
I don't see why not? They aren't pressure formed like the exhaust manifold gaskets or anything. I cleaned mine up and reused them when i took the exhaust apart....
BTW: How are the wheels coming along?
good luck!
Erich
good luck!
Erich
Rennlist Lifetime Member
I replaced mine. They aren't that expensive and I figured pay for them now or pay for them later when I am chasing down an exhaust leak.
My dowpipe crush ring was the only one I had a tough time with. Absolutely would not come out - I had to cut into it with a dremel and pry it out with a screwdriver.
All the other ones actually fell out of their channel, thats why I didn't want to reuse them - I doubt highly they would have created a good seal.
I definitely would not reuse any of them on the crossover pipe. The high pressure those joints will see will need the best seal you can give them.
