944 starts for a second then dies
Lazer Beam Shooter
Well i went and tried to find out why my car was running horrible. A bunch of lines were torn up and stuff, i think that was the problem. I called porsche they said that i could tape them temporarly until we get new lines. I taped them and put everything back together, now the car will only start for a second or two and dies, even if i give it gas. Does anybody know whats wrong? All of the vacuum lines are in correctly. I taped up the hose that goes from the idle stabilzer to the intake manifold (theres a little piece of metal that connects that hose to the intake manifold and its really beat up. Could that be it).
Any help would be awesome thanks.
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
tape didnt do the trick. I've tried, its not easy... go buy the stuff and replace it, or else you dont have a car till then. tape is nearly hopeless.
~Eyal
~Eyal
Check for an intake-leak near the AFM. If air doesn't flow through the AFM, you won't get an accurate air-flow signal and you'll be too lean. Also check the wiring-plug for the AFM. If it's disconnected, or the wire is broken along the way, the DME still squirts a little fuel to crank and start, but then if it doesn't see the AFM signal, it turns off the car.
