Turn signal does not work with parking or headlights on
I have a '91 944S2 and out of the blue the oddest issue recently popped up. All of a sudden the left turn signal will not work when the parking and/or headlines are on. Just the left side and only when the parking and headlights are on. If I turn the parking or headlight off, the signal will work and alternatively, if the turn signal is on and I tun on the parking or headlights the turn signal stops working (see attached video). I recently had the front bumper cover off and double checked all the lights after reassembly and everything worked fine. Any ides what could be causing this issue?
Thanks in advance.
Thanks in advance.
Ed Petry (09-11-2022)
Thanks, will take a look at what happened. There was a few weeks between the two events but will seek out any grounds or wires that could have been impacted.
