Porsche 944 Idles
Old 08-27-2022, 08:58 PM
enatera214
8th Gear
enatera214's Avatar
FINALLY!!!!! Just about an hour ago I found my issue. I removed the accessory belt connected to the alternator and AC compressor and viola... it runs like normal. Or so it did. I parked it in my driveway, and now when I try and start it, it starts, idles, and then dies when I touch the gas pedal. Vacuum leak maybe? I'm not sure what caused the sudden change.
Old 08-28-2022, 12:34 PM
Zirconocene
Zirconocene's Avatar
Have you taken a look at the TS-01 on Clark's Garage? Here's the link, if not: http://www.clarks-garage.com
The 2nd thing listed to look at, after the DME temperature sensor is vacuum leaks. It says to inspect all hoses but, in your case, maybe you have something else going on at the intake manifold.
Good luck
Quick Reply: Porsche 944 Idles
