Early 944 brakes
A guy I know is willing to give me four sets of calipers (two left, two right for an early 944 in a parts swap along with some other stuff; anyone know if the front & rear calipers are the same? He claims they are, but I thought they were different part #s. I'd like to pick these up for a rebuild / beadblast & powdercoat job to spruce up the ride.
What is the difference between the 83' and the 84' front calipers? Do they require different pads than the 84'? Just curious due to I have both models.
TIA!
TIA!
My PTRC shows the 83 has different front calipers. That part number is for the girling calipers IIRC as VW was using Girling. Some 83s had these calipers and it was the only year they were used. I think the calipers were leftovers from building the 924's The ATE calipers were used from then on and should bolt on.
Mine are ATE as well. The part numbers listed for the 83 are the same as the 77-82 924 so what we need is a 924 owner to confirm that the part number shown is a girling caliper.
