CFM Question
2nd Gear
CFM Question
Hey guys,
I was just trying to figure out how much air our n/a engines flowed. I used the (cubic inches*rpm)/3464. And this gave me somewhere in the neighborhood of 270 cfm. This I'm assuming is ideal, and hence not that close to the actual air flowed. Anyone have a better idea of what the real cfm flow is? And does anyone know what the rev limiter is set for on an 85.5 - is it 6200 or 6400? Thanks for your time!
It depends on the volumetric efficiency at the horsepower peak rpm. The US version of the 944NA has its horsepower peak at 5500 rpm, and a VE of about 80% at that rpm. This would give an airflow of about 195 cfm. The 85.5s may have a revised cam profile that raised the peak rpm a bit and/or increased the VE a bit.
The rev limiter is set at 6,480 rpm.
Typical conversion requires knowing the VE at each RPM. Most efficient is VE=1 at the torque-peak. All other RPMs flow less air than the theoretical maximu. General rule of thumb is that max CFM = 1.6*HP. So you take HP at the torque-peak, about 125bhp. So 125bhp * 1.6 = 200CFM max.
