Help Water pump Block-off
So I read some posts that say the block off is the plastic elbow that came with my water pump. Problem is it is exactly that an elbow. air or water can flow through (I looked and tested). So I am confused at how that is a block off, and would think it would just flow right out that elbow? Someone able to explain or did I get an elbow and not a block off?
Wax Man (04-13-2022)
Unaffiliated
The water pumps are the same, the plastic elbows are either open for a water cooled turbo or closed for a dry turbo or a non turbo car. Perhaps you just need the blocked elbow instead.
Some places include a blocked plastic elbow and call it a blanking plate, as in this thread:
http://forums.pelicanparts.com/porsc...ing-plate.html
