BCI group 40R or 41
BCI group 40R or 41
So, I am going to replace my tired 6 year old Optima with a battery that fits and was wondering if I can get away with a BCI Group 41 battery or should I have someone order a 40R. They should both fit, so does it really matter?
OK, I'll bite.
I replaced my 40R with a 41 in my 968.
The extra length of the 41 makes it a very tight fit, but it does fit.
I used to have a 88 924S myself and I only used a 40R in that. It seems
that the 968 is a tighter fit in the battery box and the 924S had lots more room, but I could be wrong there.
Either a BCI 40R or a 41 are a better fit than an Optima anyway.
regards
Jon
regards
Jon
Yeah, 40R is a little under an inch shorter length than 41. Other than that the dimensions are the same.
I got the Optima to fit OK, but just OK. Only had it arc-weld once the whole time I have had it.
OK, I installed a 41 this morning. For the record, it fits but is kind of a close fit. AND, if you are using Dan's battery cable upgrade kit it is an almost uncomfortably tight fit. I had to trim down the negative side bolt to keep it from possibly touching the firewall. It does fit, but close.
