Idle revs drop when warm (S2)
Idle speed drops to < 400 and engine stalls whem warm. Starts and runs OK until warm. The problem turned up suddenly one day. The car is in generally good condition (< 100 000 km), no other issues.
I have replaced the DME and visual inspection does not reveal major issues with the throttle position sensor.
Is there a simple way of testing the idle control valve in situ?
Thankful for advice!
Stein
Stein
Thank you!
I applied el. contact spray on connectors and it seemed to attenuate the problem - engine does not stop. But the idle speed is still low at 600 RPM.
I have not found instructions for modifying 944 S2 idle speed anywhere.
Stein
Stein
It seems the Idle control valve is OK - it least it produces clicks when served 12V from the battery.
The explanation that the engine is running rich seems reasonable to me.
How do I fix that? What is the culprit?
