Ignition switch question
Lazer Beam Shooter
Hey guys I'm so close to fixing the car. While i was checking up on stuff i pulled the ignition switch to see how that was doing. Well i pulled the back cover thing off and all of the wires popped out. I put them back in and i thought i did it right because everything seemed fine. Then i noticed a winding sound, its real faint, coming from by the fuse box. Then i noticed the fresh air blower relay was really hot so I pulled that out and the noise stopped. I think I messed the wire order up.
Does anybody know where which wires go where? (I know the big red one goes to 30 and the big red one with a black stripe goes to terminal 30) There were like 4 other terminals. There was X , R , 15 and another 30. Thanks in advance.
I wish I could help you but I just looked at the 86 wiring diagrams and all I got was a headache. I just can't seem to follow those things. If you have a Hynes manual you may find your answer in there. Chris could help you out on this one.
