No Spark, No tach bounce. Don’t know what else to change.
I hope you have solved your problem already. It sounds like you may have recently acquired this car. Have you ever seen or had this car running well or did you tow/trailer it home?
You comment a couple of times of excessive fuel; is it possible that your injectors are not closing, that is they are just opening and staying open constantly spraying fuel from all four? If so that sounds like perhaps a bad aftermarket DME chip? Good luck.
