leaking clutch slave cylinder
The clutch slave cylinder on my 86' 944 has a slow leak. I replaced it about 4 months ago, but it still drips a little down on the pedals. Every 3-4 weeks I've been having to add fluid. I've been using cheap brake fluid. Any chance switching to a premium fluid might stop the leak or should I just pull the cylinder out again?
Chris
Chris
Hey Man
It's your Clutch Master cylinder that's leaking and you should change the slave also while you are in there. This is a very common thing with the 944. I've done both of my cars in the last 6 months..the second time only took me about an 1-1/2 hours total. Follow Pete's link above...it's really fairly easy with a pressure bleeder and the Clarks-Garage write-up.
Good Luck
Good Luck
Are you sure it's coming from the cylinder itself and not a connection? Bad new cylinders are rare.
Check you clutch pedal for looseness or excessive movement where it actuates the cylinder. Might be making an oval out of the seals.
