Power sport seat issue
Sooooo-
Last night, I traded the regular seats in my car for a set of power leather sport seats.
Originally, my car came with a power drivers' seat, and a manual passenger seat. Once we got the seats out, I looked under the carpeting, and found a power seat connection on the passenger side. I thought it would be "plug and play"-not so.
The passenger side does not work. I tested the seats before the swap, and I know they work-it's got to be something with the fact that I added a power seat. Is there some extra fuse I need to install to power the passenger seat? Any wiring guru's want to chime in?
Thanks in advance, guy's
I'd check that plug to see if it's getting power and provides adequate ground.
I don't think the power seats have separate fuses - but the FWSM will tell you for sure.
RK
RK
I don't have a clear answer for you but I had the same setup (Power driver, manual passenger) and when I installed the power sport seats I got recently, the plug under the carpet for the passenger side worked right away.
