Need Instructions for an Air Fuel Ratio meter
I found in a box my Huntley Racing ARM1 I never hooked up. Does any one know where I might find hook up directions for this thing?
IPSC
IPSC
There should be three wires,ones ground ones power and the other gets tapped into the O2 sensor, thats how my autometer is anyways. -hope this helps-chris
There are five wires
white
black
red
orange
brown
Anybody have an old set of directions laying around? Who made the ARM1 I know huntley just slapped their name on it.
IPSC
white
black
red
orange
brown
IPSC
I've got step-by-step instructions along with photos on my RacerX website.
Rather than the involved step of extracting the pin out of the DME connector, you can just use some wire-strippers and push aside 1 /8" section of insulation from the inner wire of the O2-sensor cable after it's been separated from its insulation. Then wrap your signal-wire around it and solder. Wrap-up with electrical tape and reassemble the connector and you're set to go.
You might want to also put the ground wire DIRECTLY on the negative terminal of the battery.
There used to be issues with sensitivity if this wasn't done.
HTH!
(Hey RacerX!)
HTH!
(Hey RacerX!)
SO
If I have this right the red , white and black are the lighting wires and the brown is the signal wire off of the O2 sensor and the orange is the ground for the sensor?
IPSC
IPSC
