Battery Cables
#31
Flight 951, The supplemental ground from the front of the engine to frame rail is actually part of the headlight package. I end up selling a lot of them because they improve the grounding so much. There is something I have never been able to figure out about our car's construction that makes grounding poor. I think it has to do with the galvinizing construction methods. This supplemental makes most of the problems go away.
In any event, you can get the supplemental ground for $20. Plus whatever USPS wants for shipping.
NZ, your battery in the rear is a problem for my battery cable kit. I could make a solution for you but I would need a right hand drive car example to make it right. I don't think there are any in North America.
The headlight package will work just fine if you want to do that. And I have a supply of left hand lane E-Code lenses by Cibie. A Jaguar dealer ordered a bunch of lenses sort of forgetting that the UK and USA drive on different sides of the road. So you are covered there if you want to buy.
#32
Iceshark,
I would be in for a full set (or even the Full Boat kit). I know I need the later style negatives, with two cables. Hope you do another run as somehow all the previous offerings, I have not had the funds available.
Mine is currently fixed by my mechanic with a new clamp as the old clamp bolt was bent. Pretty sure that the cable is no good too. I've not managed to find another source - Pelican only has the single style negative.
Martin
Martin
#33
Martin, The battery negative are not a problem. You can get them now. $44 for the main plus shipping. You should get the supplemental forward ground for $20 and then things will be pretty good.
