STEERING, toe in aignment, how many Turns= Degrees
I just got a free alignment check and they gave me the print out.
Id like to know how many turns of the tie rod = degrees so i can adjust (mine were almost 2* toe in)
zero is squirrely but 1 degree on each side.
turns = 0.0175 times the distance from the spindle center line to the tire rod end then multiplied by the number of threads per unit measurement
(mm or inches for both) (0.0175 is the inverse tangent of one degree.)
