Can I remove/replace my front sway bar with ramps?
Hey everyone,
I want to replace all 4 bushings on the front sway bar to my 968. While there I would also be installing a front sway bar brace kit. Can this be done using ramps?
Thank you
Thank you
Shouldn't be a problem to do that on ramps. There are 8 bushings BTW.
I agree with Gage to try. I discovered on my 944 that changing M030 front sway bars would be difficult on ramps because the LCA needed to be adjusted with jacks to get the proper alignment of the connecting drop link
Right you are! I ordered all 8 ahead of time but you’re right. Guess I meant 4 on the bar itself and 2 on top of each stabilizer bar link, making 8 total.
Edited: because I forgot to say thank you to you guys.
Thank you!
Thank you!
