Why is this car so hot?
I know that 951's are known for giving off alot of heat and oozing it back into the cabin but I dont think what Im getting is normal. When I crank it all the way cold and dont have the A/C on it is really hot and nothing changes when I turn on the A/C either. After a while (maybe 7-10 minutes) the A/C will start to work but until then it feels like my face is going to be melted off. I figure if I have it set on the coldest setting i should be getting air that is the temp of the air outside. Is something wrong or is this how bad its supposed to be?
Try this:
Go to http://www.clarks-garage.com/
Click on Garage Shop manual.
Scrool dowm to Heater Malfunctions.
Yup, sounds like the infamous heater clip failure...you're gonna have to shell out big bucks for that one ($2). LOL
Get under the driver's side dash, take off the plastic cover on the lower right side and look...is there a metal rod hanging freely? Then sure enough, all you need to do is replace the plastic clip that the rod attaches to.
Good luck.
Good luck.
