Recieved AC Bracket Delete
I just got mine in the other day also. They look AWESOME!!! And a side note, would you believe someone already has one of there kits up on ebay.
Lets not forget that the AC delete kit will add 0 horsepower (unless you carry to 7 sig figs), contrary to your Ebay ad.
You've got PM.
Originally posted by adrial
If you're going to make money off Luke's hard work you should at least be accurate in how they were produced. (Water Jet, not CNC)
Its just too hot down here in FL to run without the AC. Maybe I will save the other kit for a future "track only" car.
I forgot they were water-jet'd so I just changed that. Thanks for pointing that out, I had forgot all about that because the pieces looked so nice.
Edit: I just checked it again and are you sure you saw my add. I didn't mention a HP gain from using it???
My apologies, I didnt realize Luke knew your intentions.
You're right, you didnt mention a HP gain but it seemed implied from, "With this kit you can reduce not only the cars weight but also the added drag on the engine that comes with having to turn the compressor."
Small correction is that it doesn't spin the compressor, only the pulley itself because the compressor is disengaged via a clutch mechanism.
Again my apologies for my initial response.
