Anyone still selling 87- front strut conversion kits?
It appears that Paragon and 944Online are both only offering the "we'll do it for you" option. Is the kit still available anywhere?
(Is the rubber sleeve the only thing in the kit that's not supplied with the inserts? Is it just a section of bike inner tube?)
Btw the Bilstein insert conversion kit is also still available but only from Australia, pretty quick shipping though.
jeyjey (03-27-2021)
No, I've got the Fichtel & Sachs.
Did you go with the weld-in adapter from New Zealand or the weld-in motorcycle exhaust nut?
Another question for you guys: where do the Bilstein B6s fit in relation to the adjustable Koni's on full-soft?
For Bilstein (when they are available again) the options are part no’s 34-000403 and 34-001042. The 34-001042 has higher rated rebound better suited to uprated springs. The 34-000403 work great with the stock springs.
The following 3 users liked this post by MAGK944:
It’s a kit made by @beamishnz that lets you use the Bilstein inserts instead of the Koni ones. It’s basically a very nicely machined weld-on adapter that makes your late struts like the early struts with easily removable inserts held it place by a stock Porsche screw on cap.
Noahs944 (03-28-2021)
Definitely Paul's kit from New Zealand. Fantastic quality, the only holdback is supply of the strut inserts from Bilstein. One point with the Bilstein conversion, bump rubbers are not needed since the Bilstein's have those built-in internally. Also, the Bilsteins come with their own dust boots.
Bilstein's are shipping in EU.
Any luck State-side yet?
