Need some help here / What have you repaired or replaced on your car???
The list below is what I have so far. I am compiling a "list" of sorts and I know I am missing some things here. What have you repaired or replaced on your 944???
Ball Joints Fuel Pump Head Gasket Radiator Hoses Oil Cooler Seals Timing Belt Water Pump Rotors Torque Tube Clutch Rings Connecting Rods Valves Sun Visor Clips Sun Roof Door Handles Hatch Seal Turbo Rod Bearings Front Seals Rear Seals Pressure Plate Strut Inserts Tie Rods Rod Ends Break Pads Interior Trim Wheels AFM Intercooler Vacuum Hoses Balance Shaft Belt Lifters Valve Springs Break Booster Gauge Cluster Seat Upholstery Headers Main Bearings Oil Pressure Relief Valve Power Steering Rack DME Injectors Wiring Harness Front Fenders Fog Lights Bumper Pads Strut Mounts Locking Lug Nuts Parking Break Control Arms Motor Mounts Distributor Cap Spark Plugs Spark Plug Wires Chips KLR CV Joints Oil Radiator Air Conditioning System Flywheel Sensors Thurmofan Switch Headlights Muffler Crossover Pipe
Clutch (and associated goodies like pressure plate, bearings, etc.),
clutch fork,
spark plugs,
oil,
coolant,
CV joints (repack),
trans. oil,
valve seats and guides,
parking brake handle,
odometer,
odometer gear,
belts,
rollers,
waterpump,
clutch hydaulics,
sunroof clips (front),
rear shocks,
head gasket,
tires
02 sensor
Ground cable (icechark)
Battery
Windshield wipers
Removed:
A/C system (soon)
Windshield washer stuff
Plan to replace:
Balance shaft seals
Spark plug wires
Distributor
Shocks
Sway bushings
Control arms (takes care of bushings and BJ's)
Steering rack boot
Brake pads
Fuel filter
Muffler
headlights (iceshark)
Coverlay dash (or something similar)
Vacuum hoses when they go
clutch fork,
spark plugs,
oil,
coolant,
CV joints (repack),
trans. oil,
odometer,
odometer gear,
belts,
rollers,
waterpump,
clutch hydaulics,
rear shocks,
head gasket,
tires
02 sensor
Battery
Windshield wipers
Removed:
A/C system (soon)
Plan to replace:
Balance shaft seals
Spark plug wires
Distributor
Shocks
Sway bushings
Steering rack boot
Brake pads
Fuel filter
Muffler
Ok, Added the extras to the list.. .who else???? I know I am still missing stuff.
You guys will like this when I am done so chip in if you can.
Diverter Valve
Wastegate
Ever seen PET?? That is pretty much my list :>)
BTW- Brake is spelled the way I have it there when referring to the items on the car and break in referring to what these cars do on regular basis!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Wastegate
lets see...
ive done
break pads
air filter
hatch and hood seals.
remounted ac
replaced lower radiator hose
ac switch
steering wheel
rear hatch struts
rear shocks
rear hatch latches
rear hatch switch
interior lights
door light switches
door handles
oil
tranny oil
coolant flush
brake fluid flush
fuel filter
fuel line
tires (over the summer)
radiator (next winter)
steering fluid
you prob have everyhting, but just thought id try
ive done
break pads
air filter
remounted ac
ac switch
steering wheel
rear hatch struts
rear shocks
rear hatch latches
rear hatch switch
interior lights
door light switches
door handles
oil
tranny oil
coolant flush
brake fluid flush
fuel filter
fuel line
steering fluid
Brake Master Cylinder
Brake Calipers
Brake Lines
Clutch Master Cylinder
Clutch Slave Cylinder
Suspension Bushings
Ball Joints
Rear Shocks
Fuel Pump Check Valve
Fuel Pressure Regulator
Fuel Injector Seals
Windshield Washer Pump
Windshield Waser Lines
Wiper Switch
Steering Wheel
Spark Plugs
Spark Plug Wires
Rotor
Distributor Cap
Ignition Switch
Motor Mounts
Headlight Relay
Headlight Wiring (IceShark)
Ground Cable(IceShark)
DME Relay
Radiator
Radiator Hoses
CV Joints
Sunvisor Clips
Radio
Oil Filter
Air Filter
Fuel Filter
Rear Axle Bearings
Front Axle Bearings
Spedometer Cable
Clutch (again soon)
Main Seal
Camshaft Seals
Seat Belt
Seats
Door Latch Cable
Thats all I can think of right now.
Brake Calipers
Brake Lines
Suspension Bushings
Ball Joints
Rear Shocks
Fuel Injector Seals
Wiper Switch
Steering Wheel
Spark Plugs
Spark Plug Wires
Rotor
Distributor Cap
Ignition Switch
Motor Mounts
Headlight Relay
DME Relay
Radiator
Radiator Hoses
CV Joints
Sunvisor Clips
Radio
Oil Filter
Air Filter
Fuel Filter
Rear Axle Bearings
Front Axle Bearings
Spedometer Cable
Clutch (again soon)
Main Seal
Camshaft Seals
Seat Belt
Seats
Door Latch Cable
Windshield Waser
Spark Plugs
Spark Plug Wires
Rotor
Distributor Cap
Ignition Switch
Motor Mounts (2 times)
Headlight Relay
DME Relay
tranny oil
coolant flush
brake fluid flush
Radiator Hoses
Radio
Oil Filter
Air Filter
Clutch kit
Main Seal
Camshaft Seals
head gasket,
tires
Rings
Connecting Rods
Valves
Windshield Waser
Spark Plugs
Spark Plug Wires
Rotor
Distributor Cap
Ignition Switch
Headlight Relay
DME Relay
tranny oil
coolant flush
brake fluid flush
Radiator Hoses
Radio
Oil Filter
Air Filter
Clutch kit
Main Seal
Camshaft Seals
head gasket,
tires
Rings
Connecting Rods
Valves
DME Relay
Hood shocks
Wires running from the fuse box to the back of the brake
thermostat
turbo thermostat
turbo thermostat housing
thermoswitch
heater clip
battery
intake manifold (and gaskets)
power steering belt
balance shaft
adjusted timing
soon to do
clutch master and slave
timing belt, balance shaft belt
waterpump
rollers
vacum lines
radiator
coolant expansion tank
steering wheel
shift boot
turbocharger
O2 sensor
fuel rail
wastegate
Hood shocks
thermostat
turbo thermostat
thermoswitch
heater clip
battery
power steering belt
balance shaft
adjusted timing
soon to do
waterpump
rollers
vacum lines
radiator
steering wheel
shift boot
turbocharger
O2 sensor
fuel rail
wastegate
Coolant tank
Washer tank
Washer pump
Washer hoses
Oil/Air seperator o rings
Belts/Rollers/Head rebuild
Dash trim
Face gauges
Battery box repair!
Brake lines
Fuel lines
Various hoses
vacuum lines
deleted AC lines
Clutch Master cylinder hose from resevoir
Starter
Starter
Distributor cap/rotor
Plugs
Washer tank
Washer pump
Washer hoses
Dash trim
Face gauges
Battery box repair!
Brake lines
Fuel lines
Various hoses
vacuum lines
deleted AC lines
Starter
Starter
Plugs
