Coolant types
Old Mar 28, 2004 | 10:10 PM
Porsche-O-Phile's Avatar
Porsche-O-Phile
Default Coolant types
I'd like to flush my coolant sometime soon (I'm not sure when / if the p.o. ever did it) but don't know the recommended types of coolant that will work okay with the aluminum engines in these cars - any suggestions?
Old Mar 28, 2004 | 10:12 PM
Chris_924s's Avatar
Chris_924s
Nerd Herder
me too.. me too.
We should come up with a FAQ for recommended fluids.. we all have the same change intervals. I know the antifreeze has to be safe for aluminum engines, but which is best for our application?
Old Mar 28, 2004 | 10:13 PM
ELLSSUU's Avatar
ELLSSUU
Geaux Tigers!
Use the search. The question comes up every few weeks. For me, I use Audi/VW blue and distilled aqua.
Old Mar 28, 2004 | 11:36 PM
Yabo's Avatar
Yabo
clarks garage had recoomendation it hink
Old Mar 29, 2004 | 02:46 AM
Porsche-O-Phile
bump
Old Mar 29, 2004 | 02:58 AM
Matt O.'s Avatar
Matt O.
Lifetime Member
Dexcool -- the orange stuff. Just look on the bottle and it will say something like "safe for foreign aluminum engines" or something to that effect.
-Matt
Old Mar 29, 2004 | 05:54 AM
Porsche-O-Phile
Yea, but I've heard not to trust such labels - are you using that stuff right now and if so, how long, what kind of temperature ranges, etc. . .
Old Mar 29, 2004 | 09:59 AM
Zero10's Avatar
Zero10
Don't ever go just by the label, if it says 'safe for aluminum engines'.
Check to make sure it also says 'phosphate free', because they can call it safe for aluminum engines if it's LOW phosphate as well. So be on the lookout for that.
I use Prestone Long-Life, it's Phosphate and silicate free, orange, and says 'GM-Dexcool approved' on it. It was pretty cheap too, I think $10/4L jug.
The vw/audi blue stuff should be fine, but I bet it's a little more costly as well.
I think there are some of the green antifreeze's that are phosphate free, but they are fairly rare.
Don't ever just put in el-cheapo green stuff from Zellers or whatever.
Old Mar 29, 2004 | 10:02 PM
p0wp0w's Avatar
p0wp0w
is there a way to see what type of coolant you have without draining it?
I'm low on coolant but my reservoir is too yellow to tell what type it is...
Old Mar 29, 2004 | 11:12 PM
83na944's Avatar
83na944
Stick an antifreeze tester or a tube or drinking straw and get a sample. If it's orange, its the Long Life DexCoool stuff. If its green its not. If you can't tell, it time to change it anyway.
Old Mar 29, 2004 | 11:22 PM
Matt O.'s Avatar
Matt O.
Lifetime Member
If I remember correctly, Dexcool is phosphate free.
I have used it since I purchased my car and my temp gauge never gets above the second bar. Of course that was after a new waterpump, radiator, etc... I don't think I've ever seen the orange stuff that isn't phosphate free. Basically, just get the orange stuff.
-Matt
Old Mar 29, 2004 | 11:31 PM
pete944's Avatar
pete944
I was at Autozone today and the had Zerex G-05. It says it's phosphate free. I usually use the orange Dexcool stuff. The Zerex is yellow. Anyone ever use this stuff?
Oh, Matt, I cleaned out my pm box.
Old Mar 29, 2004 | 11:41 PM
83na944's Avatar
83na944
I'm sure my car had green antifreeze in it when I got it back in '85 with 11000 mi. I'm sure it had not been changed. I wonder if that stuff was Phosphate-free.
Old Mar 29, 2004 | 11:42 PM
ERAU-944's Avatar
ERAU-944
how much are y'all paying for tha vw/audi blue stuff?
-Mike-
Old Mar 30, 2004 | 02:00 AM
reno928s's Avatar
reno928s
We once had this disscussion on the 928 board and the final result was that the dexa-cool or orange anti-freeze is good but if the coolant ever runs very low it has a tendency to gel up. It was a tie between the BMW brand which is blue or the one I use which is the Audi/VW brand which is also blue. I had zero problems with the VW brand (blue) in my previous car (928) and now I use it in my 951, it seems to run a bit cooler. Remember the blue, green, and orange anti-freeze's are NOT compatible with each other, so if you go blue you must top off with blue. Reno
