Rear Hatch Struts
#31
+1 for the Jeep Wrangler Struts
Thanks for the tip. These were perfect for my 1988 924S. I had removed my rear wiper motor, so my hatch is lighter than stock. The force is exactly right - no separation, plus my hatch lifts gently on its own when I use the hatch release button in the driver door well!
Perfect new struts!
Perfect new struts!
Just a heads up I purchased these and they are very "neutral" in how much force they create. Basically enough to hold the hatch in place wherever you lift it to and maybe ever so slightly lift the hatch. They say they are for a 87-95 year jeep Wrangler. I think they also include male connectors to connect your defrost to which you can see in the product photo (I don't have a rear wiper or use rear defrost so left mine disconnected).
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Model #SG214008
PO had replacement struts that were WAY too strong and would force the hatch up with a good deal of pressure. This is not what you want because that upward force is what is going to cause separation (as mentioned)
Model #SG214008
