Curil-T Removal
Old 01-24-2021, 07:52 PM
audi49
audi49's Avatar
I recently used the below to remove the gasket for the 944 oil pump and for residual from the oil pan gasket. I tried all sorts of other chemicals in my garage on the oil pump gasket but nothing worked (acetone, paint thinner, goof off...). This product worked very well, but did have to apply it 2 or 3 times to get it all off. It is Methylene Chloride and so I was extremely careful... special chemical resistant gloves, goggles, well ventilated, face mask.
Loctite 135544 $16.59 Chisel Gasket Paint Stripper, 18 Oz. Chisel(R) | Zoro.com
I'd also recommend a hard plastic scraper to help scrape the stuff off without damaging the surface. I used the below (found these to be very useful in the shop).
Amazon.com: ARES 16003-6-Piece Non-Marring Pick and Prybar Set - Protects Fasteners, O-Rings, Seals, Gaskets, and Trim on Automotive and Electronics Applications During Use: Automotive Amazon.com: ARES 16003-6-Piece Non-Marring Pick and Prybar Set - Protects Fasteners, O-Rings, Seals, Gaskets, and Trim on Automotive and Electronics Applications During Use: Automotive
Old 01-25-2021, 06:26 PM
Dan Martinic
Dan Martinic's Avatar
Originally Posted by 16again2009
I've never used them, but I saw in a post where a guy used plastic razor blades to clean his gasket surfaces.
The plastic razor blades that I've tried are crap and a waste of time.
Old 01-30-2021, 11:43 PM
Luis A.
Luis A.'s Avatar
Fashion a scraper like this from copper pipe and carefully sharpen the edge with your bench grinder so it’s even across. Won’t gouge the aluminum and it’s a very effective scraper.
The following 3 users liked this post by Luis A.:
Jay Wellwood (01-31-2021), mj951 (01-31-2021), Noahs944 (02-01-2021)
Old 01-31-2021, 03:41 AM
tempest411
tempest411's Avatar
After experimenting with a bunch of different methods when I did a head gasket last winter, I arrived at the same conclusion. Keep a honing stone handy though, as the copper loses it's edge quickly, which is actually a good thing. It only takes a few swipes on the stone to get it back, however.
I wonder why copper scrapers aren't more popular?
Old 01-31-2021, 08:47 PM
Tiger03447
Tiger03447's Avatar
The Egyptians used them all up a very long time ago..LOL!
Old 01-31-2021, 10:30 PM
PerryB
PerryB's Avatar
Thanks again for the suggestions. I ended up using a new single edge razor, brake clean, a green scotch-brite pad and lots of care. I was able to get all of the sealant off and not damage the surfaces.
Old 02-01-2021, 01:37 AM
tempest411
tempest411's Avatar
Regarding the scotchbrite, I've read multiple warnings against using it because it sheds aluminum oxide particles, which is 'evil stuff' to have inside of an engine or gearbox. I realize I'm just parroting stuff I've read on the net. I guess it depends on how paranoid you want to be.
Old 02-02-2021, 12:17 AM
KevinGross
KevinGross's Avatar
Yeah, that's a little too paranoid. I've use brown-ish 000 pads for 25 years on hundreds of transmissions, not a problem. At a minimum, you'll wipe down the surface afterward with a shop towel, maybe moistened with brake cleaner, to clean it up real good. Often, the gasket scraping precedes a trip through the parts washer as well. So a little pad dust really isn't going to be an issue.
Quick Reply: Curil-T Removal
