Help me wire up my '77 924 - I beg thee!
Ok, I now see that my friend wired my ignition coil wrong. I really really hope this is why my car isn't starting, but I need you guys to help me wire it back up:
Here's a picture of my current setup. Note the unused top of one resistor and how the wire on the left resistor goes to the coil, which I now think is wrong due to pictures from when I first got the car. (and the car ran based on that previous setup) They showed that wire attached to something else, but I'm not sure what.
![](http://www.electricporsche.com/engine.jpg)
In instructions that a small boy can understand, please tell me how to wire this thing back to life!
Thanks guys,
-Jeff
Thanks guys,
-Jeff
All the 924 wiring diagrams are online at www.pelicanparts.com.
It's just going to take some time to trace them out. Try using crayons or colered markers.
Good luck.
Ray
Good luck.
Ray
If I remember correctly (I am about 700 miles from my 924 otherwise I would look) the resistors are wired in series - one connects to the other. From there, I can't remember. But remember not to tighten the coil terminals very tight... I broke off one of the studs last time I cleaned the resistor/connector mess!
hmm, well looking at some digital pictures I had from the engine initially I have it working...but the resistors arn't wired in.
I'll be looking into it later...BUT MY ENGINE RUNS! And that counts for alot.
-Jeff
-Jeff
