Springs for Koni yellow inserts ('83 944)?
Stock springs look like they have linear spring rates (no diameter changes)..considering at Hypercoil/Swift/Eibach.
I know that Koni Yellows have adjustable rebound so the spring choice isn't too vast, but I am looking to decrease roll in 80mph sweepers.
Basically looking for M030 suspension setup but with cheaper alternatives. Any recommendations?
You’ll need coilover struts to fit Hyperco, Swift or Eibach springs, they don’t make springs for the stock struts, afaik nobody does. While increasing the spring rate will help somewhat on roll, you will be better off upgrading your sway bars. Last time I looked 944/951 M030 sways were not to expensive and would be a straight swap for your current sways.
Yes Sway bars will be upgraded. Thinking of 23/14mm or 26/16mm
I was suggesting 944/951 M030 f&r sways as they are cheap, plentiful and an upgrade for stock 1983 944 sways. M030 springs or any aftermarket springs like Hyperco won’t fit your struts. Like I said, you need coilover struts and then you will have an almost infinite choice of spring rates.
So even the M030 springs will not fit the stock strut housings? That's new info.
Is this a track car? What is the diameter of the rear torsion bars? I have testing suspension data for my '83 944 on suspension setups, what does not work, what is better, and what is the best. Lots of self-inflicted bad setups until I got it right. So my experience is data and test driven.
M030 front and 3 position adjustable rear sway bars are the best approach. The diameter of the sway bars need to be with the effective spring rates of the front springs and the rear torsion bars. Spring Rate is not effective spring rate.
The rule of thumb is the front effective spring rate does not exceed the rear torsion bar effective spring rate.
So it is important to know the rear torsion bar diameter to start the process.
The Koni shocks are on the stiffer side for non adjustable compression and rebound is adjustable but stiff for all the effective spring rate combos.
If your struts are toast and you want to up the spring rate you have two choices:
get a set of coilover struts from Ground Control, KW, etc; or
convert your current factory struts to coilovers using a sleeve and fit Koni or Bilstein inserts.
Both these options will allow you to choose any spring you desire.
I am trying to figure out if a larger diameter front sway bar would work with Koni Yellow & stock non M030 springs.
If compression is on the stiffer side that's exactly what I am looking for but I would want a little more gradual rebound. The car is mainly for street but looking to autoX/light track in the near future. The car will be installed with LR ultra mounts as well.
I should also add that I have Bilstein HD rear shocks. Looks like they are valved 235R/119C.
Handling wise I prefer slight oversteer as I think these underpowered NAs could greatly benefit from faster turn in.
Rear torsion bar is stock so likely 23.5mm. I know 14mm rear works because that was the factory option, along with 23mm front.
Also why are you fitting Lindsey Ultra Mounts, they are far inferior to stock hydraulic mounts, they will cause vibration and your fuel rail and oil pick up tube will be stressed.
Its a bit confusing trying to figure out what you want to achieve. If you are running a 23mm front sway then that is already an upgrade from the stock bar on a 1983 car. Your (Koni yellow) inserts are used to control the springs not the sway bars and you generally match the sways to the springs not the inserts or dampers. On our cars when you start to get above a 200 pound front spring rate the 968 M030 front sways work well but I see no advantage in increasing the sway bars rate from you current upgrade if you are still going to run stock 160 pound front springs.
If it was my car I would fit the coilover sleeves onto the stock struts, Koni inserts, 220 front springs and 30/19mm sways. Then lower the rear to the lowest on the eccentric and level up the front or even a slight forward rake using the front coilover adjustment. It's a proven old school setting for these cars and likely your cheapest and easiest option.
voodu3 (11-07-2020)
Lindsey Racing has M030 sway bar mounting bracket for early 944 front lower control arms. If OP wants slight oversteer, then I believe 26.8mm or 25.5mm front sway bar will work with 19mm rear sway bar. The front sway bars are available used from dcAuto Porsche dismantlers
