Oil Pressure mysteries
Old 03-20-2004 | 10:13 PM
Matthew West's Avatar
Matthew West
Angry Oil Pressure mysteries
This problem is now over 3 years old. I have posted numerous times and searched the archives and I still haven't figured it out.
On startup after the car has been sitting for a couple of hours. I have no oil pressure. It takes 15-45 secs to register oil pressure. The lifter make bad noises so I don't think this is a sender or ground problem.
It used to be the car had to sit overnight for the problem to manifest itself. Overtime it has taken progressively less time, last time the car ran it only took a couple of hours.
If I park the car on a slight incline facing downhill the problem does not occur.
It would seem that oil is draining back to the pan. Parking on an incline may prevent this. The rate at which oil drains back has been increasing over the life of this problem.
What I have done:
1. Had two different professional mechanics from different shops check the oil pressure relief valve. (3 times in total)
2. I just finished dropping the oilpan myself. I really really really expected and hoped to find a cracked oil pickup tube, but did not.
So please tell me if you have ever had a similar problem and if so how it was resolved.
I have read some stories about oil pump sealing. (But have been unable to find the necessary details.)
Old 03-20-2004 | 10:20 PM
KuHL 951's Avatar
KuHL 951
Hey Man
How many miles? Is the pressure normal after driving it awhile? It is strange that it has been going on for 3 years now and hasn't crapped on you yet. I think you are on the right track with the oil pump sealing though.
Old 03-20-2004 | 11:16 PM
Matthew West
170,000 miles. Oil pressure reads on the high side of factory specification once it registers.
Old 03-20-2004 | 11:46 PM
ahofam123's Avatar
ahofam123
My money would be on the pressure relief valve. I visually checked my valve three times before replacing it. It wasn't until after I replaced it with the updated 1 piece valve that my pressure delay problem stopped.
Old 03-21-2004 | 03:05 AM
Zero10's Avatar
Zero10
What brand oil filters do you use?
Old 03-21-2004 | 10:38 AM
Matthew West
Mahle
Old 03-21-2004 | 10:51 AM
Charlie's Avatar
Charlie
Try a different OPRV. If you do a search of my post you will find I could not get my pump to pull oil from the pan, it turned out to be an OPRV problem. The OPRV valve can let air into the oil passage from the oil pan to the pump, so I would try another valve to eliminate this as the problem.
Quick Reply: Oil Pressure mysteries
