Hey, this is impressive.
Old 03-20-2004 | 10:03 PM
Peckster's Avatar
Peckster
I had a Ducati with a huge diameter four-leading-shoe drum brake on the front that was as good as any disc on the market. Cost more to make them.
Old 03-20-2004 | 10:27 PM
FSAEracer03's Avatar
FSAEracer03
TRB0 GUY
Originally posted by fpena944
I think on most cars the majority of the braking force gets pushed towards the front of the car. That's why drums at least in the back probably are not that bad. Also the reason why our front brakes wear out much faster than the back pair.
But four-wheel drums is probably a disaster waiting to happen - especially in a performance environment.
Very true... about three quarters of the braking force is done by the front brakes. If you ever ride bikes you'll notice that the front brakes are not only more effective, but also all you really use except in bad conditions. And ever wonder why spirited driving leaves you will brake dust covered all over your front wheels? The weight is transferred to the front of the car under braking (as seen through dive) and gives more responsibility to the front wheels to stop the car.
Old 03-20-2004 | 10:54 PM
prophesized's Avatar
prophesized
my dad and i both have the same body style camrys except his has rear drums and mine has 4 wheel disc. my car definietly stops alot faster than his.
why are there light marks on his tires at the end of each spoke?
Old 03-21-2004 | 03:18 AM
Dmitry S.'s Avatar
Dmitry S.
Originally posted by FSAEracer03
That just isn't true Miguel, I'm sorry. The drum rears on my old Honda don't perform well in any conditions... and have you driven a car with ALL wheels trying to be stopped by drums?? You better plan ahead because it'll take you twice as long!
It is true. On the firt stop, Drums will perform better than discs (assuming that the pad material is the same), because the pads have more surface area, and if the drums are dual servo action (most) the movement of the car helps in braking. After this, the drum brakes heat up and stop worse than disc, but they are initially better.
Old 03-21-2004 | 01:33 PM
Danno's Avatar
Danno
There was some guy asking about cross-drilled brakes a couple of days ago. I can't find that thread here now. You know, the one where they pointed him to the 30-page Altima board "discussion".
Old 03-21-2004 | 01:38 PM
sharky47's Avatar
sharky47
Set to Full-Auto
Heeeeeeey, don't make fun of all-wheel drums, my 356 has em on all four corners!
Quick Reply: Hey, this is impressive.
