Now WHY don't you want a sunroof?
Ok, I just realized the '77 924 I bought has no Sunroof, which is apparently somehow special or good?
But....why?
I mean it sure looks stylish, but is the sunroof that detremental to the form of the car?
-Jeff
But....why?
-Jeff
i dont knwo what i would do if i didnt have my removable roof, its the greatest driving at night in july being able to stop at ever stoplight and look up and see the stars.....
some of my fondest memories of my car involve that roof.....
awesome
awesome
Sorry Z-man, Matt's got this one. Porsche added a lot of steel to the roof when they cut the sunroof into it, so much that the sunroof car is often considered to be more rigid than the non-sunroof chassis. The downside is weight, all up as high as posible and in this case a stronger roof is (hopefully) not all that helpful.
Originally posted by Z-man
A non-sunroof car has a stiffer chassis, which is a plus in racing.
-z-man.
-z-man.
Originally posted by Cass944
would'nt the car be lighter because you could just take the top off?
BUT...
or is there some rule saying you have to fahe a roof on your car when racing?
Older cars weren't exactly concerned too much with saftey. In any of the SCCA races with Boxsters, they run with hardtops. Most (if not all) require some sort of protection for the driver and something to restrain your arms from getting crushed.
You won't see many 944/968 cabs at the track. Cars like the Cobra get their strenght from a ladder style chassis or from a tubular frame, for them a top doesn't matter, they are usually just required to have a roll bar. A 944/968 cab is also usually required to have a rollbar, but a unibody doesn't react well to having it's top cut off. Porsche did an admirable job of reinforcing the cab chassis but it is still not as stiff as a coupe, flex in the chassis equals less in the handling department. A 944/968 cab is heavier than a coupe which has a negative effect on performance, it has more flex than a coupe, that's negative number two, and you're more likely to need to install a rollbar (another expence and more weight). Not many cabs on the track.
Well, weights a factor in my electric conversion, so Woohoo I guess, heh.
How much does it shave off?
Also does anyone have an actual verified figure for stock '77 924 coupe weight? I've gotton anything from 2350 to 2650.
-Jeff
-Jeff
