225/45/17 on 7.0J ?
225/45/17 on 7.0J ?
Is anyone running 225/45/17 kumho 712 tires on 7.0J rims?
It says that the standard rim size should be 7.5J for 225/45/17.
Will they fit on my 7.0J? I'm currently running 205/50/17.
Thanks!
Thanks!
Your wheels have an ET of 55 right?
If so thats what I was running and it worked out with out any rubbing, I ran that set up with stock struts and weltmeister springs, and also with a set of leda coil-overs, I didn't rub with either set up. (the fenders were not rolled).
here is the excessive body roll I had before the leda's
I use that size as well. As to going wider, they would be nearly impossible to mount even with a run flat mounter. They work well with a 255 on the rear.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
