Anyone in SE Va have Iceshark's kits?
I have them in the DC area...I'll tell you that the craftsman ship is top notch...much better than other wiring kits I've seen on other cars. Installation was fairly straight forward, but you will scrape up your arms feeding the wires behind the radiator shroud. The lights are amazing...one of my favorite parts on my car, and so often overlooked.
Rennlist Lifetime Member
I'll second Rich on this one - the quality of the kit is second to none, and the lights are so much better you will be amazed.
Rich - did you ever get your headgasket fixed? Haven't seen you on the boards in a while - hows it goin?
Paul,
I got the car back together, and it runs good, but I am swapping my 400# springs on my coilovers for some 200# springs since I lost my 30mm torsion bars before I got a chance to install them and the car understeers badly. Sadly, the car is out of commission for a little bit because some dip**** broke my pass. window and stole everything out of the car a couple of weeks ago (I should have a new window shortly though...).
Mike,
I'm going out of town this Friday for 10 days (spring break) but I can help you when I get back. The hardest part of the whole install is getting to the alternator because you have to pull all of the intake stuff off. If you want to wait until a week from Monday, I can definitely help...with two people it would probably take 2 or 3 hours to put in.
Mike,
"streckfu's951", is trying to look at the battery cable kit, not lighting, guys.
While a comparable for quality it is not the same construction and wire gauge.
Originally posted by ribs
Mike,
I'm going out of town this Friday for 10 days .... If you want to wait until a week from Monday, I can definitely help...with two people it would probably take 2 or 3 hours to put in.
Mike,
thanks
