attn: part car owners -- i need a fuel line
this line isn't too hard to get at. it's between the fuel pump and fuel filter located under the rear of the car. on end has a banjo bolt fitting for the fuel pump. the other end has a threaded fitting for the fuel filter. if you have one of these hoses in good condition, please please please drop me a line at ljamesdickinson@yahoo.com.
I'd be willing to bet that if it's like the other rubber lines on the car, the crimp on style ends can be cut off with a dremel, and regular (cheap) fuel line used with hose clamps. The ends will look like regular ribbed inserts once the crimped on piece is removed. Might be a cheaper route, assuming you have the hose. Worst case, try it, and if it doesn't work, you are just back where you started.
