koni shock adjustment?
just a hopefully quick question,
i have a set of yellow koni's to install in my 89 s2, no adjustment instructions came with them (slightly used)
i know there is a hole in the top housing, how are they adjusted and
what is the recommended setting for street use?
thanks in advance
buckshot wi
thanks in advance
buckshot wi
Hey Man
The Koni site has the instructions for these. On mine you have to remove them from the car, pull the rubber bump stops from around the shaft, compress them all the way in, and turn them either direction to figure out where rebound was set at. If I remember correctly CW is full hard at stop;
CCW is full soft. It's been awhile.
