Close up of the Big Rotors / 996 TT Calipers
Well I was asked for a close up of the 345mm x 35mm rotors / 996 TT calipers mounded up on my car....
Ask for and you..... (well you know)
and one of my the 965
KPV do you know the specs for the factory rotors? I know they are 34mm wide, but are they 345mm? 350?
I'm not sure they will fit with my set up, i'm currious to know if they will, but i'm betting that they will not. But this is a time I would love to be proved wrong.....
because they do, these rotors are only temporary, there was something wrong with the casting of these and they did not wear evenly, but they will get the job done of the time being (the car dosn't run yet)....
Jason,
The calipers are the stock 996 TT Calipers, they are the modern monoblock design.
The rotors are custom 2 piece rotors, they have floating rotors and aluminum hats.
Pads, well right now I have a 1/2 worn set of padgid Orange pads in there, i'm not sure what i'm going to run when I replace these rotors. I'm thinking that i'll have two sets of pads, something for the street, and then something a bit more aggressive for the track.....
But who knows, the budget is dry right now, so i'll run what I have for the rest of this summer.....
