Turning the crankshaft to TDC
I have used the OT mark on the flywheel, and it worked just fine for me.
I don't know if all cars have this, but mine has a flange inside the rectangular hole, which comes just shy of touching the flywheel. When the line is perfectly lined up with the flange, then it's at TDC, just make sure the cam is correct as well.
But yes, it is a real pain to see in there with everything installed. I pulled the intake manifold and oil/air seperator (part of my project), and it was super-easy to see.
I looked all over the back of the engine for this mysterious "rectangular hole", but I can't find it through all the wires and stuff. I think I'm going to try the "wooden dowel" method, it seems pretty simple.
thanks to all...
thanks to all...
Wooden dowel with out checking the rotor (or the cam - same thing) is right only half the time.
I would find the hole (it's above the sensors) as you will need this reference for doing timing and balance belts.
So cal brought up a good point i forgot to mention. The cam turns a different number of times for every time the crankshaft does, so it can be 180 degrees off at one point....another revolution will straighten it out....i almost freaked like a dumbass when mine was off 180 degrees
In short: Looking at the flywheel TDC mark or using a wooden stick to find the piston TDS does the EXACT same thing. You must check that the cam is not 180o off either way you choose to check the piston TDC
Regards:
Eirik Kvello-Aune
www.944968.com
