I haven't verified it myself, but I found this...
The Air Conditioner Relay is a 6 post relay and is located behind the glove box to the far right. There is a small relay panel there that holds this relay and the Fresh Air Interlock Relay. The glove box has to be removed to access.
That’s what I thought. I also read about this relay panel, but I can’t seem to find it. That’s why I took the glove box out in the first place.
I recommend removing the hvac unit to clean all of the large contacts on the back. Examine the solder points. There are 2 solenoid relays back there I think. One controls the flapper to mix the air, which might get activated when you turn off the a/c. It never hurts to clean your grounds of you haven't.
