944 Relay/ fuse box
So why can I not find anything on what part number / relay goes to which spot. If I google the part #s it shows multiply uses. On the 928 International it shows the part number with the relay that goes in the location. Somebody has have this.
It sounds like you want a single, go-to reference.
http://www.autoatlanta.com/porsche-p...section=903-05
G1 94461511900 relay for blower 1 $6.25
G2 141951253B relay for kl 15 1 $7.50
G3 92861520300 relay for rear window heating 1 -
G4 1H0953227 flasher relay 1 $2.50
G5 99361522701 relay for - dme - 1 $31.00
G6 94461018306 adapter for cars with fog headlamp 1 -
G7 94461511600 relay for power window 1 $98.05
G9 99361510100 switch unit 1 $55.50
G9 99361510101 switch unit 1 $48.00
G10 94461510404 relay for 2. motor fan 1 $264.71
G11 141951253B relay for fog headlamp rear fog light 1 $7.50
G12 94461511900 relay for fog headlamp 1 $6.25
G13 141951253B relay for fanfare 1 $7.50
G14 191937503 relay for kl x 1 $6.35
G15 92861811100 relay for headlight washer system 1 $105.97
G16 92861810203 relay
G17 94461511501 relay air-conditioning switch 1 $46.88
G18 94461511702 relay lifting roof 1 $221.37
G19 95161814902 relay for water pump turbocharger 1 $213.24 TURBO G20 92861512403 relay anti-lock brake system 1 $88.05 M593 G21 94461511302 relay for alarm system
(FOR YEAR 1988 & up) 1 $73.28
(FROM YEAR 88 UP) 1 $73.28
This is not an ad. I'm far too lazy to delete the links and prices, etc...
dzaprev (06-15-2020)
Thanks!
