10 speaker in 1990 944 S2??
Breakaway944 - here’s a new unit released by Sony in Dec 2019 that has a built-in amp and generate 45 W RMS per channel.
https://www.sonicelectronix.com/item...-DSX-GS80.html
Has Bluetooth, USB, phone support, but no CD players. Seems to have really good reviews so far.
When you put a system together you want to match the components to each other. I am in the middle of putting my "budget" system together. Alpine type R 6.5 comps up front, Pioneer 6x9 in rear and an amp at around 450w RMS at 4ohms. I experimented a lot on my e36 with different sized speakers/subs and I settled on this combo. Good speakers up front (I wished I would have taken the speakers out of my e36 when I sold it, they were fantastic, but they were also $700!) and 6x9 in the rear for filler and bass. I just put the Alpines and HU in. I hooked the Alpines (110 W RMS/each) to the head unit and turned it up. It sounded horrible. I used to have the speakers in a different car with a 440W amp. Turning up the sound with an amp is like getting a calf massage. With the HU amp I do not even notice the speaker. Since I run an aftermarket amp I do not have to worry about a crappy amp in the HU putting out a lot of noise, so I use a cheap HU.
I have a cabriolet so my choices are dictated by the space available to me (as are everyone's!) and they are also dictated by how nice I want the system to sound. You can never get bass out of a 5.25 speaker, you need to go bigger (at least I need to). I am not looking for a high end system, just something that will blow away pretty much any factory system.
Bottom line, to have a good sounding system takes a lot of research. Match your speakers power requirement with the amp output. Even though my alpines are bigger and cost more then yours, yours will sound better driven off a HU because mine require sooo much more power. Match your components!
Breakaway944 - Thanks for this informative reply. I know nothing about this stuff, and I'm just looking for a reasonable improvement over my current older Alpine CDA 9833 which I think has 14 W RMA. My budget is really low too ($400 max), not because I can't afford it, but just because I can'y justify it. I have other things on the car that I want to address, that are more important to me. I may just spend $200 on this, and get it from Best Buy, where I can get a no-hassle 30-day return, and worst is I wast a few hours of my time working on it and then revert back to old HU.
