Rebuild advice, to the tune of the "Beverly Hillbillies" big images!
I just have to ask. Was your car leaving a smoke screen behind it just before teardown? Just kinda curious, I've been thinking of re-ringing my engine because it smokes so bad coming out of a decel. Same kind of story with compression and leakdown. With mine, its definately #2. I see scoring when I looked at it with a fixed borescope, but can't tell how deep they are of course. (not as much scoring as seen in your pictures though). My current smoking engine is only a "temporary" also. I've got the original engine in the process of rebuild. Good luck on yours!
The oddest thing- I was pressurizing my crankcase, blowing out oil from the back of the balance shafts and the dip stick tube. No clever tricks completely solved that. My undercarriage is well lubed now.
Originally posted by Tom M'Guinn
For what it's worth, my car has similar scoring on two cylinders and has been running fine (over 300 to the wheels) for over a year.
Did you re-ring when you put yours back together?
Originally posted by Steve Cooper
At the risk of sounding like a nit-wit, how would you define "catch the edge of your nail"?
I'd guess it to be that if the nail hooks and snaps off the edge of a scratch, while being dragged acorss the scratch, that would be a "catch", as opposed to feeling the smooth, subtle ridges of the scratch with your nail, which would not be a catch.
To re-ring, I'm going to need to drop my pan, aren't I? Ick! That was a pleasant job.
I'd guess it to be that if the nail hooks and snaps off the edge of a scratch, while being dragged acorss the scratch, that would be a "catch", as opposed to feeling the smooth, subtle ridges of the scratch with your nail, which would not be a catch.To re-ring, I'm going to need to drop my pan, aren't I? Ick! That was a pleasant job.
Fresh rings can cut away some of the minor scuffing and help keep the motor going... at least for a while. Eventually you'll wear out the block, but I think spending a few days and a a few $100 is worth saving $5000.
Also, since you'll be pulling the piston/rod assembly, you can toss in new bearings, check end play on your crank, and check the wrist pin clearances. (worn wrist pins allow scuffing to happen, and ovaled cylinders)
Perry,
$155 for a set of rings- that sound about right to you? http://cgi.ebay.com/ebaymotors/ws/eB...tem=2465223842
I get the feeling I could make this job easier on myself if I were to drop the motor, what do you think?
Originally posted by Perry 951
I'd drop it, but that is me. It all depends if you have the equipment and time to do it with.
