Dme Fried?
Dme Fried?
Is my Dme fried ; it runs horrible and it makes no diff. if i remove the 2nd or 3rd injector wire but the 1st or 4th kills it .. it was running fine ; what do yall think happened
"it runs horrible and it makes no diff. if i remove the 2nd or 3rd injector wire "
The injector wires are paired 1 & 2 and 3 & 4. Looks like you've got a break in both your injector #2 & #3 wires after the Y-split. If the break was before the Y-split, both your injectors on that trunk would be dead. Carefully peel back the rubber boot on the #2 & #3 injectors and you'll that the wire is broken right where it joins the connectors.
Due to the difficult square-shaped retainer springs on the injecors, many people are tempted to pull on the little wire loop coming out of the injectors, never every do this!!! Always remove both ends of the retainer-spring with the tip of flat screwdriver. Then pull on the connector itself to remove from the injector.
