I got lucky (fixing the cruise control)
On my 1991 944S2:
Symptoms before:
- No response when pressing cruise lever
- Cruise immediately speeds up 10mph when it does engage
Actions:
- Removed cruise control board above hood release
- Noticed many, many solder points on board and almost gave up.
- Re-soldered maybe 25 points that looked dull
Results:
- It works now! The only catch is that when I press the lever forward to speed up, the accelerator pedal 'pulses' maybe once a second as the car speeds up. That part feels odd, but it does work.
Could anyone tell me what might be the problem with the pulsing acceleration? Maybe I should clean the servo in the engine compartment?
thanks,
Bryan
Symptoms before:
Actions:
Results:
thanks,
Bryan
I removed the board and coulnd't really see any bad solder joints.
Are they REALLY obvious?
If it's not the brain - what's the next thing to check?
I have same symproms - moving control lever has no effect 90% of the time - once in a great while, trying to set it will make the car accelerate - but the speed will not hold.
Second post I have seen that mentioned resoldering the contacts and unit worked. Mine does not work and I don't care at this point. When I get time I will have a look. So sorry Bryan not much use to you now.
Triscadek, you told me about the gas warning light. Today I finally drove mine down until it came on. Nice yellow light. I had a gas can in the back just in case the bulb was no good! Thanks.
Originally posted by triscadek
Happy it works, didn't have faith in the light Eh?
Sorry Bryan about the hijack.
