Damn 944 S2 horn.
Damn 944 S2 horn.
One of my cars has a horn that is not working. 1. I’ve checked the relay it is good.
2. I check the horn button it makes the relay go click. Good.
3 i’ve checked the ground wire at the horn and it does in fact go to ground.
if I remove the horn and put the positive and ground on my multimeter I do not get any voltage when pressing the horn. Somethings seems to have gone afoul between the positive wire at the horn and the other end at the fuse box.
Any thoughts on what I should be checking next?
Any trouble with blinkers/hazards?
Look underneath dash at the back side of the fuse/relay box. There are a lot of plugs plugged into the back. Make sure all the plugs are plugged ALL the way in. The horn plug is on the row closest to center of car. Try this.
