New Sneakers! 205 or 195?
After ten years, it is time for some new rubbers.
http://www.944time.com/porsche/tires.php
When I first got my 944 (non-turbo, 1986 model), I though bigger was better, so I got 225/60s.
After those wore out, I went to 215/60s and noticed much improved acceleration.
I am thinking of going to 205/60 or even 195/60. Smaller diameter, less mass, better for the mostly-urban driving I do.
Anyone use those? I am afraid 195 might be silly looking.
205/215 = 0.95 or 95% as wide.
195/215 = 0.90 or 90% as wide.
My old tires are well-worn. I can break them loose when it is wet!
Ten Years On
Ten Years On
Just a car guy
You are not taking into consideration the overall diameter. If you go narrower and maintain the same aspect ratio (60 series) you will lose on diameter. This will help acceleration, to a certain extent, but you will also lose ground clearance. The stock tire was 215/60R15. Is there a good reason to deviate from this?
Unless you are looking for winter tires, I would be hesitant to go narrower. Narrower tires will 'break loose' more easily too.
Good point about the lowering.
205/60 would drop the car about 1/2 inch.
195/60 would drop the car about 1 inch.
I don't think 1/2 inch would be a problem. But one inch?
I'll have to go measure my current ground clearance.
I was more concerned about 195/60s looking stupid.
Amazon has some low-priced 195/60R15 tires: $33 shipped for SUPERMAX All-Season!
https://www.willtheyfit.com/index.ph...h=7&offset2=40
James G. (03-02-2020)
When I first bought my 944, 10-year-old tires were on it. They didn't hold much grip at all. I run stock front and rear sizes...but my odo is still 6% fast like many others here...
