968 M030 or 944 S2 M474 ?
Hi guys,
I may have the opportunity to make a killer deal on a set of four new 968 Konis M030 shock absorbers (the ones which the rear units are coil overs).
I currently have on my S2 four M474 Konis with non M030 968 CS springs (same stiffness as M030, but in the smaller S2/968 diameter so they fit the specific M474 S2 Koni struts).
My S2 handles great as it is now.
My question is : would you "upgrade" to the M030 units, just for the sake of making a great deal and risk losing the homogeneity of the current suspension set up or leave the car as it is now ?
I find my suspension to be stiff enough for the quality of roads I drive it on ... but I can't help thinking I will certainly be kicking myself in the future if I let this deal pass.
Thanks in advance for any opinion.
Thom-
I think it depends. Do you miss haveing external adjustability on the fronts? I have the same M474 set up pn my S2 and would like to have the adjustablilty up front for the days I am autocrossing. I would also like a bit more spring rate in the rear, but that is just me. BTW if you pass on these, how about passing the info along to someone over the pond....
Best,
Best,
